What brand of amp. is good?
JOHNNYM35
Car: 06 INFINITI M35
I was wondering what brand of amp. is good and what do I look for when I get one? There is a crunch amp. on sale at fries and I was wondering if thats a good brand? thanks
chinaonnitrous
Car: 2002 Maxima to 2004 Evoloution to 1992 Integra
Wh
JOHNNYM35 wrote:I was wondering what brand of amp. is good and what do I look for when I get one? There is a crunch amp. on sale at fries and I was wondering if thats a good brand? thanks
what are you going to use it for?
Subwoofer?
Door speakers?
usually crunch isn't a great brand, but it does function.
JOHNNYM35
I was planning on using it for subwoofer.
JOHNNYM35
What about MTX?
WCCBaLLeR
MTX is better than Crunch by far. I personally like JL Audio sub amps. A little more expensive but way cleaner output. Very powerful.
Chad
JOHNNYM35
Thanks alot, thats true and for the car that its going on I want it to be one of the top brands.
Can anyone tell me what r the sizes of the speakers, all of them because I want to change those as well because im already getting that nasty vibration on the door speakers.
WCCBaLLeR
You will also need to switch out the amp on the mids & highs...All of the factory speakers are 2 ohm and replacement drivers are 4 ohm so they will only get half the power. If this is something that you are interested in doing, i can give you a few pointers. Let me know.
Chad
Rex
Car: None
I have an old school Phoenix Gold MS275, if anyone is interested .
JOHNNYM35
Thanks alot man please, yes of course I would like some pointers, when it comes to sound systems and brands and understanding it all, I lackalot in that department, even if I copy someones set up thats fine with me as long as it sounds good, because I need help and I want to get them as soon as possible.
Trigger_57
Car: 2007 M35 Sport
For a great 10" sub check out manufacturer "Critical Mass". This is a incredible sub and only requires 1 cu. ft. of air. Either side of the M's trunk is sufficient.
JOHNNYM35
Ok well I was told from a guy at the audio store that If I was to get a 1000 watt amp, that it would just be to much, I would never use that to its max, I would be able to use it for six speakers. So I was thinking of getting a 500 watt amp, a JL Audio 500/1 and 2 200 watt subs. What do u think of that? Can u help me out on this please?
aurorafish1234
Car: M45 2003
I am still using a rockford fosgate from the late 1980's, whatever brands you look at make sure it feels heavy, in audio equipment the "standards" are more like "variables", a good amp will be fairly heavy, especially if it is higher wattage. I am a big fan of Memphis audio for amps/subs, not sure if they sell them in your area, but definately worth taking a look at, the JL Audio stuff is nice, but a little spendy for what you get. Size kind depends on your music taste, 10's are more Punchy(rock), and 12's go lower,dance etc. The sub enclosure makes a huge difference in how any subwoofer will sound.
