RustspecS13 wrote:I have Mckinny mounts, and my car is pretty low. The oil pan is right around level with the crossmember.
This season I'm going have my car lower and I'm going to make a skid plate for it. I may raise the engine up with a few washers, but nothing extreme, maybe 1/4in at most.
One thing about the syko mounts is you'll need a R32 crossmember. That's an added expense. And they do sit the engine higher and more forward. You might have hood clearance issues.
Either way, Syko or Mckinny you can't go wrong.
~Alex
Either company will work and both are backed by good companys . The syko mounts do not have any issue with the hood nor does it sit forward, if you have used the syko mounts you would know they are adjustable front to back, even people that use syko mounts some have luck running 2 puller fan's rather then pushers. I am running 2 pullers with no modification to my chassic. There are ton's of people on here using syko mounts and have yet to hear one bad review. Good luck to you.
