What brakes fit on a s13?
300bucks
Car: 1988 Conquest Ls1 powered
So I just picked up a s13 and it needs brakes and rotors(front) So I go to autozone and get stock 13 brakes(rotors).. pull them apart, and they are no where near the same size, almost 1" smaller than what is on my car. So I try s14's, 300zx, and a few infiniti's, no luck. That and 90% of the ppl who work autozone should be at McDonalds... they are still 4 lug, and I can't figure it out.
If anyone has a list of all brakes that work on an s13 that would be a huge help.
Thanks
masticatingcow
Car: 94 Mazda FD3S
The list is limitless. With a little fabrication, almost anything will work. How about you post up your brake setup and we tell you what you've got to order?
300bucks
If I knew my brake set up, I would know what to order. Is their another comon swap rather than 300zx that is still 4 lug? I was thinking g20, but they can't seem to find it at autozone..
masticatingcow
Car: 94 Mazda FD3S
Pull a rotor off and walk it into Autozone.
