What batteries are you guys rocking and another question
One_Love
Car: 1995 nissan 240sx
Mine just died and it kinda pissed me off, had to push the car
anyone recommend a good battery, i know optimas are like the best but do they make them with the box for the trunk ?
my battery is in the trunk.
question 2
my car seems to be missing, almost backfiring.
Some people said its mostly the coilpacks so i got some but they havent come in yet.
Can you guys think of anything else, can it be a fuel problem ?
naed240sx
Car: .....
Optimas are nice. What is even nicer about them is you can put them in open air in the passenger compartment, or whatever, because they don't leak or produce gas. You can easily make a custom tie down for them, or if you really want you can get optima boxes off of ebay.
I would post my setup, but photopost is down.
I have the rear of my car gutted, and a redtop sitting on the right side of where the rear seat used to be. I have it sitting on a battery tray, with autozone tiedown strap. It doesn't move much, never gives me problems, and passes tech.
One_Love
dude thanks a lot naed, you just made my decision.
I wanted an optima all along but wasnt sure about it, thought it might produce fumes,
OPTIMA IT IS!!!!!
naed240sx
Car: .....
No problem man. Basically you don't need a box for an optima, so you can put it anywhere and secure it with anything.
forksquared
Car: 91 Nissan 240SX coupe
98 Subaru Forester S (New DD)
i use this little beast works great
xekushnr
Car: '90 Nissan 240SX Hatch
you just bought a coilpack without even testing your current one? start simple - check your plugs. make sure they arent fouled and that they are gapped correctly. double check your timing as well. good luck semir.
xero1
Car: 08 Altima Coupe
make sure you have a good engine and battery ground.
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
I'm using an Odyssey PC-680, pretty nice if you don't have a huge power load. Very small battery, plus it's a Drycell... So no acid to worry about if the battery cracks.
0wn3r
Car: 1997 Nissan 240sx SE track car (SR20DET, caged)
i wanted to originally go optima when my battery was going... ruled that out as totally not needed though.
went to A/A and just got a Titanium. plenty of cold crank power, etc.
Gramentz
Car: s14
I'm rockin the cheapest one I could find at walmart. WOO!
