2011ACdarkslate wrote:I've already stated I don't know much about rims an backspacing etc....... I know I want 20s, staggered, an will be lowered on eibach springs. What width would you recommend??
Not trying to be a douche, but you should do at least some basic research and figure out what everything is/means, and how it all works together (a starting point -
altima-suspension-brakes-rims-and-tires.html). Some people here like wide rear wheels with semi-ridiculous amounts of camber to make it all work, others like a nice clean tuck, others don't want to stray anywhere from OEM. So you're probably going to get responses that are across a wide range of styles/tastes.
And some people think they know what they're talking about, and will reply with something that is totally ridiculous for the situation. It's best to know what everything means before you take the advice of someone that tells you that +25 offset will tuck fine and not rub (on their 8" wide rims), so you should be fine too (on your 12" wide rims).
