what axles????
BHFR-GTR
Car: 1993 s13
im putting a na z32 rear in my s13 drag car and cant get a clear answer on what axles i need to use, any help would be appreciated
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Its a R200V its not much different then a J30VLSD except it uses the 4.08 ring gear and not the 3.92. You need J30 Axles or 5bolt S13 VLSD axles.
So all your doing is putting in a 4.08 ration VLSD.
Now some guys use the 90-94 Q45 diff which are also R200Vs but with a 13 tooth pinion and a 3.68 ratio. And with this set up you need to use a Q45 axle on the passenger side, and a Z32 turbo axle on the drivers side. So you end up with much stronger axles. And the lower final drive. Great for turbo car and the exles are much beefier.
heartofaskyline
Car: 1992 hatch, 1993 sr20 coupe
^^ive got skyline r33 axles and there almost twice as beefy as the stock ones are
BHFR-GTR
Car: 1993 s13
thanks a lot, that is a big help, are the skyling axles 5 bolt and would work for my setup. and once more thanks i have been getting the run arround
steeda763
Car: '91 S13 SR-Coupe, '96 BMW M3, '95 525iT
Any particular reason you're using a viscous differential for drag racing?
BHFR-GTR
Car: 1993 s13
its a brand new diff, and it was given to me, so for the time being i am goin to use that to get the car going and to the dyno, because at 800hp i am going to need more than one wheel pulling on the dyno.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
I make 500 NA horsepower with tons of low end torque. I am running a hybrid r200 / r230 diff, but the carrier is a welded R200.
placham
Car: 1992 Geo Prizm (4AFE)---Gone
1990 Nissan 240sx Coupe (RB20DET powered),
1994 Toyota Celica GT (3SGTE swapped), 1995 Nissan 240sx KA24DE,
2011 Nissan Sentra SER Spec-V
N/A 300zx/Z32 diff= Stock axles, unless it's one of the 5 bolt flanges like older J30's. But ether way those axles (n/a300zx and J30) fit the stock 240sx wheel bearing/hub.
heartofaskyline
BHFR-GTR wrote:thanks a lot, that is a big help, are the skyling axles 5 bolt and would work for my setup. and once more thanks i have been getting the run arround
yes they are 5 bolt, so i imagine they would work
BHFR-GTR
Car: 1993 s13
supposedly the 300 axles will bolt on but are to long, because the suspention sits out farther on the z
placham
BHFR-GTR wrote:supposedly the 300 axles will bolt on but are to long, because the suspention sits out farther on the z
Dont know bout that, I got Q45 VLSD with Drside axle on my Drside from 300zxTT and Q45 Drside axle on my Passide. So you can mix and match, but I dont know the length since I never measured them.
