rico05 »
https://forums.nicoclub.com/rico05-u8176.html
Fri Feb 04, 2005 6:25 pm
Subframe bushings preload (by compression) the old rubber bushings making them deflect less, effectlively making the subframe mounted more stiffly to the unibody. I noticed more rear end stability on decreasing radius turns with a slight slip at the rear. THe car used to kind of float or rock on the subframe (shifting in its own chassis if you will), now I can't feel any weird weight shift. Kinda nice. Oh yeah...Rest of the list:
-Nismo S-Tune coilvers-Tein inner/outer tie rod ends (spacer installed)-ProjectSilvia PB T/C rods-JDM K's 21mm rear sway bar-Whiteline endlink bushings-Nismo front STB-Falken Azenis Sport 205/50/15EDIT:- I also have a set of Cusco front strut upper mounts sitting in my garage. I wanna put em on and take a few pics of -3^ camber before I go get an alignment
Some sort of bushing kit is in the works. Maybe.
Modified by rico05 at 10:02 AM 2/5/2005
