Loveless wrote:if 195-200F is normal range then my stock setup is fine
either way, look into greddy oil pan,.. adds 1qt, finned for cooling, and the trap door to keep the oil from moving around
some argue that oil cooler is an over kill for a street car and that you dont want your oil too cold, then nismofreak's suggestion of oil thermosstart for oil cooler would make sense. Still, it's a **** load of money. I would just get the pan and call it a day.
The pan's only for sr20's though right? I've never seen a greddy one for a ka.
Anyway, yea, if you add an oil cooler, consider going all the way and getting a thermostat for it.
Also, You "may" want to look into synthetic oil, which arguably helps new & old engines a like - this is a debateable point, but read and come to your own conclusion. Also, synthetic oil runs at a higher temperature than normal oil efficiently.
