What Are you using to controller your fans?
SlowKoop
Car: 350z s13 coupe
I was looking into a dif ver. d controller, but heard some stuff about relocated batteries. Just checking to see what most people with E fans were using.
1. I would like to use stock temp sensor.
2. Not trying to break the bank.
3. Also wanting to keep it clean.
LeD ippen
Car: 1993 Nissan 240sx SE
i used a thermo switch from auto zone comes on at 185 off at 170. comes with relay and wires
http://www.autozone.com/autozone/parts/ ... 326162_0_0_
they also have probe types and adjustible ones
SlowKoop
Car: 350z s13 coupe
Does it have an over ride switch so if you want you can run the fans below 170 also?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
I use the motor to control my fan.
touge whore
Car: 93 coupe rb/ 86 ae86 sr20det
i use a plain jane switch that i leave on all the time
legit240sx
Car: 91 240sx rb20
$40 napa fan controller, thermostat probe into the rad by on of the outlets. 180 F to 220 F . works great but basic of the basic...
SlowKoop
Car: 350z s13 coupe
The thing I like about the dif is it will stay on for 30 seconds after the car is shut off. Also it can control 2 different fans at different speeds.
LeD ippen
SlowKoop wrote:Does it have an over ride switch so if you want you can run the fans below 170 also?
it does not come with a switch but it does allow optional override.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Be careful. Those radiator probes don't last long. I switched to a Dif after the probe I was using broke after a few months. Waste of money IMO.
flatrate
Car: S14 kouki
i have mine wired thru my engine managment...they come on when the ac is switched on as well
TimTurboZ
Car: 95 S14 w/RBXX... 65' Mustang GT
Relay that is switched on when the fuel pump comes on *IDC if the fans are on b4 operating temp is reached* I have a stock rad so might as well keep the heat in check
SlowKoop
Car: 350z s13 coupe
Yea that's whats aggravating me, when I start my car in the morning it takes forever to warm up and drop the oil pressure.
legit240sx
Car: 91 240sx rb20
Darius wrote:Be careful. Those radiator probes don't last long. I switched to a Dif after the probe I was using broke after a few months. Waste of money IMO.
thanks for the heads up
