it runs off of the Blow through MAF. it can do wideband closed loop, knock control, automapping, but it can not control nitrus or boost.I told him he could make alot of money selling it, since its not expensive to make, but it takes a while to wire, and its a pain in the *** to make. I might get directions on how to do it and try it out. from the looks of it, it will take a long time to get it right.Its not really a chip either, its a modual that runs off of the ECU, looks almost like another ecu hooked up to it. the laptop plugs in and you tune it off of thateh? wrote:Your chipped ecu can run Any sensor from any car on any system you want? Does it have boost control? Nitrous control? Defineable knock control? Automapping? traction control? wideband o2 closed loop? ect etc..If it does your friend could make a lot of money selling that eeprom here.
sounds more like the biki board.......T4 RB25det wrote:it runs off of the Blow through MAF. it can do wideband closed loop, knock control, automapping, but it can not control nitrus or boost.I told him he could make alot of money selling it, since its not expensive to make, but it takes a while to wire, and its a pain in the *** to make. I might get directions on how to do it and try it out. from the looks of it, it will take a long time to get it right.Its not really a chip either, its a modual that runs off of the ECU, looks almost like another ecu hooked up to it. the laptop plugs in and you tune it off of that
could you give me a link? because i honestly dont know what this really is, all i know is how to use ti and what it does. But i have never seen anything like it.Carl H wrote:sounds more like the biki board.......
looking at the link i dont thatink thats it since my car has been running since march with the box i have now and the bikki board was sold starting in augustCarl H wrote:http://www.bikirom.comhowever it could be one of the many devices that you can use to tweak the stock ecu.stock ecu is very good at controling high powered motors, lots of cars in japan pushing insane numbers on stock ecu's that have been retuned.
yes sirCarl H wrote:no he has a r32 rb25de+t so he has a 27c256 based ecu.right?
