what are you running?
solid
Hey this is question for the people out there that have an s14 with an s13 motor, and what do you guys run? Also it would be helpful to tell me if its stock or with what mods.
MojoMan
Car: working on cars and women
Iv'e got apex n1 cat back, straight cat, Spearco FMIC, custom piping, HKS ssqv, AVCR, SAFC, JWT, MSD 6A ign. w/Blaster coil, z32 tt plugs, ApexI n1 coilovers, z32 Brembo x drilled/slotted upgrade, and the basic ups such as dual electric fans. Im useing the ka harness which sucks. Used to have NOS. I miss it.:( Im proly missin somethings.
solid
have you timed your car yet? i was kinda wondering what times people were puting down.
Drakon
Car: S13 hatch-SR+bpu's
a mostly stock SR will run mid 14's assuming its in good shape and ur suspension is. i think with some decent mods you can get it in the high 13's. right?
nlzmo400r
Car: '02 Nissan Altima QR25DE
'93 Nissan 240SX hatch KA24DE
the sr is easily capable of high 13s, all u REALLY need is a boost controller to crank it up and if u can drive well, 14flat and lower isnt too far off, and it depends on what u call 'decent' mods, to me' decent' mods will get u a high 12sec car with an sr :)
Drakon
hehe ya. decent mods....you mean enough crap to let you boost at 35 psi?
S13240
7 psi w/ stock turbo, open differential, spare tire and emergency tools taken out. BF goodrich 205/55/16s all around on 16" Enkei RSE rims. Rear tires were pressure dropped down to 18-20 psi. Walbro fuel pump upgrade, stock dp, custom crush bent 2.5" exhaust, greddy front strut bar, intrax springs, kyb gr2 struts, and K&N filter. Trapped in at 93 mph 15.038 seconds. Ran at Fontana Dragway...no traction...I'm sure I could have done better my third time, but unfortunately time wouldn't allow it. So my best so far is 15.038. This is S13 coupe w/ s13 red top sr20det.
Drakon
thats pretty good. you using the stock SMIC?
S13240
Yep using stock sidemount w/ stock bypass valve also...forgot to mention that.
