what are these codes on my 2003 G
ramzisleiman
hello guys!.. i recently posted a thread about a throttle problem.. this problem is not solved yet!.. But i got all the codes showing using the nissan Consult II scanner!!
the codes are :P1122 P1126 and P2138
my problem is when crusing in the car.. suddenly the throttle freezes and the car almost idles!! the rpm wont rise no matter how much i press the pedal! and the vdc light and the slip light shows! if i wait for a while.. sometimes 2 min .. sometimes 15.. random!! then things work properly.. but not for long! I changed almost everything..and the codes are the same!... it is not resetting i guess!.. today i changed the pedal.. i tried a used one.. since in the nissan spare parts.. there is no brand new one!..
any help would be appreciated.. this problem is driving me insane!.. and if i couldnt solve it in these couple of days.. i will sell the car!!
Edit :So i know that :P2138 Accelerator Pedal Position SensorP1122 Electronic Throttle Control ActuatorP1126 Throttle Control Motor Relay
Modified by ramzisleiman at 3:58 PM 12/5/2008
Q45tech
Follow the proceedures inside FSM where each code has a page or two of step by step test proceedures designed to narrow down the problem....................just as expert techs to repair vehicles.
Read code, do a few hours of testing, engage brain and decide what to replace.
Q451990
Did you replaece the throttle body actuator motor yet?
Heath
ramzisleiman
yes i did.. nothing changed!.. :S
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Always verify connectors first!
ramzisleiman
connectors checked!! all in place! all working fine!
