EstoMax »
https://forums.nicoclub.com/estomax-u17537.html
Wed Aug 11, 2004 2:10 pm
alright a little update on my venture____________________________________________________took a 45 degree 2 inch elbow from home depot and ghetto rigged the connectors that were on the long piece of the intake tuping onto it.
___________________________________________________then painted it black with some plastic paint
____________________________________________________mounted it.. had to cut a piece off the idler tubing, right behind the fat part of it.
____________________________________________________and finally rigged in the intake, had some fun with that, cut off a piece from the long part of the intake where it connected to the filter and had to rig it onto the intake backwards, it was pretty hard to get it on since the tubings valleys are thinner then the maf pipe.
:ylsuper max
o yeah.. one problem still, the maf wire is too short so ill cut it and extend it tommorrow..if you have any comments, ill be glad to hear em
