What are the syntoms of bad Z32 MAF?
JDMSIL80
Im trying to narrow down the problem associated with the cut-out issue of my car.
I bought my Z32 MAF from local junkyard, the car seem to idle and drives normally just like stock.
Only issue I have is now when I boost over 10psi, the cut-out would started to occur at 6000. The higher boost I go, the sooner it cuts off.
What are the chances of me buying a bad MAF? I assumed most of you guys are running used MAF just like I am.
Can you list out the syntoms and problems of bad MAF so I can see if I really need to buy a new one.
Thanks!
Modified by JDMSIL80 at 12:09 PM 10/25/2005
rchboy
I had a bad maff and the car wouldnt rev past 2500rpm so that the symptom i had.
JDMSIL80
Im unable to boost any higher than 11psi with GT28R or it will cut off around 4800rpm.
Would this be one of the syntoms and its time to get a new MAF?
float_6969
If you check the FSM, it gives you the procedure for checking the MAFS.
JDMSIL80
I do not have the factory sevice manual, my 180SX is an imported vehicle from Japan.
Is there link I can refer to?
teddy
Car: Saab Turbo and MR2
check the stickies
