You must have a bad check valve or pump because it is under pressure otherwise. Squirting fuel under the hood is a problem for most!ozzie! wrote:I didn't do any of that...Just let the car sit for a minimum of an hour after driving, then changed the filter.I had no problems.
I changed my filter last night - car sat for 4 hours then just pulled filter NO SPRAy i think i remember spray in the past, where would the check valve be ?? ANY NEG effects of bad check valve ??BTY after 8k mi my filter was dirty and i seem to have picked up 20hp,maxnix wrote:You must have a bad check valve or pump because it is under pressure otherwise. Squirting fuel under the hood is a problem for most!
easy start every timeQ451990 wrote:I think the check valve sits on top of the fuel pump... not sure though. How does it start after a hot soak? If it takes longer than after sitting all night, don't discount a leaky injector or lower o-ring. The hard start would be a sign of flooding.
Heath
