Projex240 »
https://forums.nicoclub.com/projex240-u4020.html
Thu Jan 13, 2005 1:51 pm
the best way around the cons and still having the pros--go with a blow through setup, (putting your maf on the cold pipe) & no matter what people tell you, it doesnt hurt anything. I have NEVER seen one car doing it has had problems that could be contributed to the blow through. For those who dont know-heres how it effects you in both ways:
When you maf draws air through in a "draw through" setup(maf in standard place before the turbo) it meters it and tells the ecu how much fuel to compensate for. When the BOV is atmospheric, it lets all of the air out after the maf has already told the ecu to dump in x amount of fuel. SO the fuel is still there, but the air is not. You run rich, you foul out plugs, you backfire, stutter, and die at redlights. Its sucks. I dont know why people do it at all with a drawthrough. The s-afc's decel-air function is a band-aid, and a weak one at that. It still is not a perfect fix.The blow through puts the maf on the pipe just before the TB so when it meters air, it does so with air entering the motor, and not the turbo. SO if you blow off atmosphericly, it doesnt cause problems since the air is blown off BEFORE its metered by the MAF. I personally think its a win/win situation. I havent heard of anyone with negative drawbacks to it. If so, they blamed the maf when it was something else in the end.
I forgot to mention though one thing to ensure this works right. A maf is sensative to turbulence. When placing the maf on the cold pipe, make sure there is NO bends in the piping for at least 6 inches before the maf. This cuts out the turbulence, and ensures smooth flow through the maf.
Theres some food for thought.
-Josh
