What are the PROs and CONs of an aluminum exhaust?
TwoFoutyEsEx
Car: 1997 240sex LE
Can anybody think of what good can come out of an aluminum exhaustHow about bad?
At a local store they have bulk aluminum exhaust piping cut into sections at all different angles and diameters. They fit together like puzzle pieces.If i constructed an exhaust out of these and supported the fitments with some mig welding would it work out?Would It sound good or no?
adrianfromthecastle
Car: 1992 Nissan 240sx
exhaust piping goes through a lot of abuse from heat and vibrating and moving...
I'd say the biggest con would be it potentially getting all bent out of shape from just daily driving...
mRodiek
Car: Stock Hatch
Its gonna rust right through.
Not really such a thing. That's NOT exhaust piping, it's intercooler piping, or piping from something else.
Several reasons:
Aluminum piping needs to be thicker to be as strong as SS or mild steel. Therefore, no weight savings.
Aluminum is brittle. It will crack, and that property gets worse with heating / cooling cycles. Bad choice.
Aluminum melts at 1500 degrees, but gets soft WAY sooner. Any Boy Scout can tell you, an aluminum can will burn in a campfire. Bad idea.
Aluminum corrodes. Faster when you add combustion gases to moisture, which create acids. SS is a better choice.
What you MAY be seeing is aluminized steel, which is what most new car exhaust systems are made of.
Not aluminum.
AZ89two4Tsx
Aluminized or SS is the norm. If you live in a moist climate with alot of snow, rain, etc... I'd definitely spend the extra $$ on stainless.
Fibre guy
Car: 91' s13 RB25DET, 95' s14 bone stock, 87' Wrangler 4.6L stroker
+1 for no aluminum. Aluminized for cheap/painted exhaust. High grade SS for pretty polished colors.
TwoFoutyEsEx
Car: 1997 240sex LE
If aluminum is so sh1ty then why do they sell it as 'exhaust piping'?It might be for small repairs?
mRodiek
Car: Stock Hatch
Most reputable places shouldnt build you an aluminum exhaust...because its crap!
AZ89two4Tsx
If domestic cars are such garbage, then why do they sell them?
TwoFoutyEsEx wrote:If aluminum is so sh1ty then why do they sell it as 'exhaust piping'?It might be for small repairs?
How is it that you're convinced that it's "exhaust piping"? Is it labeled as such?
Perhaps the seller is an idiot.
Perhaps it says, "Aluminized Exhaust Piping".
Perhaps they MEAN "Aluminized, but the seller is an idiot and doesn't know how to spell.
Regardless, none of this changes the laws of physics, and the metallurgic properties of aluminum.
I think the question you meant to ask is, "Why am I convinced there's a shop selling aluminum tubing for exhaust systems, and if they are, why are they doing so?"
Papi Chulo
Car: 72' Datsun 510
Pros and cons of toilet paper roll exhaust?
Pros - Plentiful and cheap.
Cons - Don't drive through a puddle.
mRodiek
Car: Stock Hatch
AZ89two4Tsx wrote:If domestic cars are such garbage, then why do they sell them?
1990-240sxsr20det
Car: 1992 s13 Coupe
Its just gonna rust, it'll probably rust fast or get warped in a lot of spots too. Spend the extra money on some sort of steel exhaust system
NismoZRS
Car: 92 S13 Coupe
lul wat
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
A aluminum exhaust will not rust... corrode yes but not rust.
It will be weaker, but as long as built with proper clearance, should be fine.
It's a cheap exhaust overall, and may lat a decent while, but you should just go with a ebay stainless exhaust (I did, fit great, but is a little low) or if you want a true quality exhaust, get a BRM catback. Superior quality and reliability compared to ebay..
EDIT:
If the store stocks aluminum exhaust... it's ALUMINIZED MILD STEEL.
For some reason I thought you meant real aluminum exhaust like IC piping.
Anyway, aluminized exhaust will last for years before rusting beyond repair(5-8yrs)
Soravia
Car: 2003 Audi A4 1.8T
It ain't the Aluminumnized steel rusting. The weldings rust sooner than anything. I would recommend painting the exhaust with High-temp exhaust paint after getting it back from the exhaust shop.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Its actually 1220.66 degrees. Get it right CEO, damn!
AZ89two4Tsx
Sorry not ALL domestic cars are garbage. I guess it was just an exaggeration. It's more of a 50/50 thing.
