This is a direct copy and paste from the 240sx.org FAQ
240 History, Basics, Info, etc. This info is located at the bottom of the page... -------------------------------------------------------------------------
What is the difference between base, SE, and LE('97-'98) S14 240SX ('95-'98)?
This is something I put together from responses to my qustion I posted to the list. I didn't keep track of the names, but the credit goes to all of those knowledgeable list subscribers.
S14 240SX trim line comparison==============================LE is only for '97 and '98 modelsBelow is what an SE has:
Exterior========- 5 lug 16" wheels (base has 4 lug optional alloy 15" wheels)- Body colored outside mirrors- Fog Lamps- Rear Spoiler (side rocker panels on 97/98)- Dual Chrome Exhaust Finish- '95: Power antenna standard (so as in LE)(for base, needs 6 sp,CD,amp system)- Sunroof optional (same in base, standard in LE)- Front lip spoiler
Interior========- Air, Cruise, and tilt- White-faced sports gauges- Power everything (base has optional Power package - incl. A/C, locks, Cruise)- Variable intermittent wipers (fixed in base)- 6 speaker sound system (std in LE, '96+ base has radio & speakers optional)- Maplight (without sunroof)- Upgraded cloth seats- Driver's side lumbar support (95/96)- Optional Leather and Security package- Keyless entry standard in '95 SE (optional in '96)- Leather wrapped steering and shift nob(manual transmission)- Passenger side vanity mirror- Leather and Security optional (not available on base, standard in LE) - '95-'96: door trims on the leather package in black seude- '97-'98:door trims on the leather package in titanium- '97-'98: side sill extensions
Mechanical- optional VLSD and ABS package (VLSD order option for base) (VLSD and ABS in a single option, if an SE has VLSD, it will have an ABS as well - vice versa)- Sports suspension and rear stabilizer bar. - '95: larger front strut piston (22mm vs 20mm)- '96: larger front strut and rear shock piston '96: leather interior and ABS/VLSD options were combined
Naoki WatanabeEmail:
[email protected]
Hope that helps answer your question...
Nicole
