Are they for anything? I was thinking they could be there to help air pass through when the car is moving. but usually dont u put a flap or something? ie when theres not alot of front airflow, the clutch fan will pull air more through the radiator?
Postby
Fibre guy »
https://forums.nicoclub.com/fibre-guy-u128603.htmlMon Apr 27, 2009 4:12 am
A late reply but I have a possible answer.The A/C fan was on the left lower side. Sound logical?Also no flap because of the distance to the belts. I got to look how everything worked while it was all together in my front clip.
Postby
krayton »
https://forums.nicoclub.com/krayton-u8223.htmlSat May 02, 2009 1:52 pm
SullivanRacing06 wrote:allows the ac fan to blow air thru the shrowd and dosent allow the clutch fan to pull cooler air thru, id think theres a flap missing from it tho!
yep, except its not a flap, the cut out butts up against the radiator
finally got mine in. but yeah, just fyi ing it for archives
