bmlawless »
https://forums.nicoclub.com/bmlawless-u85265.html
Wed Sep 24, 2008 4:21 am
Blue smoke = oil, black = fuel, white = water. As long as you don't have white, you can still drive it.
It's OK to use some oil. My wife's Rabbit has almost 300,000 miles and uses/leaks almost a quart between oil changes. The trick is that she has been changing the oil religiously since 1985. Although it isn't good to let the oil go 15,000 miles without a change, that won't kill an engine on it's own.
Your smoke, codes, and crummy idle are all related. Fix those and you should have a decent running rig. If you are still burning a little oil and it is not noticable, don't worry about it at 159,000 miles. Just change the oil at the proper intervals and keep an eye on the levels.
