float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Sun Jun 10, 2007 8:36 pm
Turn the key to the "Run" position. Check the striped wire at each injector. You should have 12V+. If you don't, then you've either got something wired wrong, or your dropping resistor is bad.
