Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Nov 13, 2007 6:19 am
With individual TB, selecting the point [length from air horn to closed valve] is critical as to where [what rpm] the wave reinforcement occurs based on after BDC...........cams and length interreact to form the boost in torque over a narrow rpm range.
The oem air duct/plenum/runner design boosted torque at 1550-2000 rpm, 3800-4400, and 5500-6,000 rpm expect to lose 4, 8, 12% peak torque below your new tuned length rpm.
Some of this can be made up from less restriction by muliple throttle plates.
Measure oem TB at WOT it has a maximum of ~~ 8" W.C. [1.7%] use a manometer across TB to measure restriction.
Be sure to taper the runner [4-6 degrees] from horn to head to braoden the rpm where the reflect occurs and to strengthen the ram effect.
