Zadok wrote:Forgive me, dumb question about Rocker Arm Stoppers!How hard\whats involved in installing RAS in a Redtop.And why is the Greddy RAS so much cheaper?
Took about an hour to install the rocker arm stoppers. very simple to do.
some points about it though.
-you will need an inch/lb torque wrench. -follow the FSM for loosening and torquing cam caps. -you will need some nissan liquid gasket-when putting the valve cover back on, put the gasket in the valve cover before hand.-it may take a little force to seat the valve cover, do not be afraid to tap it with a rubber mallot.
Other than that, nothing to it.
