what are the best and cheap upgrade to do on the ka?????feel the power....
raul_gotbeat
Car: nissan 240sx
where and hhow much are some cheap upgrade and tricks that u can do to the ka to feel and have more power(hp)........???????
spindrift187
free mods. Advancing timing/make your own intake/remove all that uesless emissions crap(more of a visual mod but I hate it all)/and for sound id just remove the intake resonator.
The best bang for the buck I have come across is getting your motor fresh:Spark plugs/wirescap/rotoroil/coolant changePCV valve02 sensor
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
Back when i was rocking a ka in high school..I did ever mod to that engine and my favorite mods were my Hotshot header and my Injen Cold air intake..
raul_gotbeat
Car: nissan 240sx
did you get the extension for the injen cold air??? cause i have the injen intake but its short ram...
9240sx
Yes..I could feel a differents with the extension over just the short ram.
raul_gotbeat
Car: nissan 240sx
how much was it for the extension????
CRyan
Car: 1997 Nissan 240SX
spindrift187 wrote:free mods. Advancing timing/make your own intake/remove all that uesless emissions crap(more of a visual mod but I hate it all)/and for sound id just remove the intake resonator.
How much would you propose to advance it?
Razi
Car: Moo
Best....Turbo?Cheap....fixing random broken shiz
Best and Cheap usually don't go together.
r0ccsteady
Car: 1989 240sx
baaaaaaaahhhhhhhhhhhhhh!!!! suck a fat one raul!i gotta 240 now..
raul_gotbeat
Car: nissan 240sx
shut the **** up....240's suck ***... hahaha J/K
MoldyOldy240
Car: 1991 240sx 295K w/ original engine.
fix broken crap; fix your suspension (you don't know it, but its broken...generally)
240_fun
Car: 92 Nissan 240sx Hatch, 2000 Ford Ranger XLT
you can also do a custom short ram to the opposite side of the engine bay if you put the battery in the trunk. I did that and the sound from it was orgasmic. pep boys dude... little filter, 90 degree bend, short straight piece that can hook th eold lines up to it...http://viewmorepics.myspace.co...72738idk if that link will work but its a sweet set up itll sound sick even without an exhaust if u SEARCH more you'll find other people who have done this tooditch the injen they're mad $$$ and they dont even do as much as this short intake would do for less than a third of the priceif ur poor like me and 17 name brands are of no concern
S13psi
Car: '92 Hatch
one cheap, easy way to gain some power (or mileage, depending on your driving) is to add 2 - 3 oz of acetone per 10 gallons of gas. you can get acetone wherever paint supplies are sold, including autozone. this will clean up your fuel system very well, and it gives a little more umph. i have seen a noticeable difference in smoothness, idle, and acceleration.
note: i use it every time i fill up. when i don't, i notice it.
another thing that is cheap and easy is to put a small hose on your distributor cap vent, and run it into your manifold somewhere after the throttle body. this will suck out the ozone (o3) created by the arcing. O3 burns more readily than O2, thus slightly improving combustion efficiency.
note: if you do the ozone mod, it is necessary to drill a small hole in your dist. cap to let fresh air in. Otherwise, the vacuum created in the cap may pull oil from the crankcase. you dont want that.
i have performed both of these on my own 240, and i can say from experience that they both work well.
ps i found these from a mileage website called mpgresearch.com
Modified by S13psi at 2:22 PM 1/18/2008
S13psi
Car: '92 Hatch
mpgresearch
240_fun
Modified by S13psi at 2:22 PM 1/18/2008[/QUOTE] it.
One of the vacuum lines that goes to the PAIR system is a vacuum line.I'm tossing that so i could just use that one right?
S13psi
Car: '92 Hatch
if you were just tossing it, i guess so.
Kristine
Car: 1992 Toyota Paseo
1997 Nissan Altima
Battery relocation and bend a pipe to the left side, then drill some holes where the battery tray is to let some air through. Rueben (-RJ-) did that to his S14 and it sounded pretty mean.
Price:Battery box: $15 at walmart14ft Jumper Cables: $25 at Autozone4 screws: 11 cents45 degree pvc pipe: $9 at AutozoneFilter : $20
About 70 dollars for a meaner sounding car and 5 hp lol XD
then you can do an eletric fan mod, thats virtualy free. Just rewire your eletric fan and remove that clutch fan. I heard it frees about 10hp (correct me if I'm wrong)
Oh and use Royal Purple Oil lol, 4 quarts of that is $26, that gives hp too.
Oligator
Car: 240sx vert
Strip the car like you do with gurl.You will got 5 hp. hahaA real answer.... exhaust cam on the side of the intake and boummmmmmm10 hp With a better power band
Kristine
1997 Nissan Altima
but exhaust and cams are expensive
Oligator
Car: 240sx vert
50 bucksYou dont understand what I mean. take a exhaust cam of a stock ka24DE and put on the side of the intake.
hakosuka86
Car: Toyotas Nissans
thats true! 1991 cams are best on ka. for cheap!!is a good upgrade for s14. my s13 its a 91 so im good.
is it worth it taking off the cat??
is the acetone on the fuel tank safe?? which type of acetone??Ill give it a try i is safe and worth it.
morbid
Car: alot of s***
turbo
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
N60MAF and a SAFC...Used N60's you can get for $50, and used SAFC's for $100 or more.
d3vilskid
Car: 240sx '95 coupe
depending on wat yr 240sx u have. say if you have a 95+ use the 91-94 model exhaust headers. Use the avi(i think thats wat its called) for the secondary o2 sensor, its a 4-2-1 compared to the 95+ 4-1 headers.
Oligator
Car: 240sx vert
N60 maf? Whats that? Im sorry I dont search but I see you write that. And why a safc if your not turbo?
Oligator
Car: 240sx vert
ohhh god Im sorry. hahaha I dont check correctly your post. A lot of people say the stock maf of a ka is good. But if your turboing go for a z32 maf.
Bigvinnie
Oligator wrote:ohhh god Im sorry. hahaha I dont check correctly your post. A lot of people say the stock maf of a ka is good. But if your turboing go for a z32 maf.
WTF are you talking about the KA MAF sucks!!!!
justjuiceit4
Car: 1993 Nissan 240SXs, (Coupe and Convertible) 1994 Infiniti Q45
You can get a dry nitrous kit for about $100. I have not tried this on my 240SX yet, but on my Nissan truck KA24E, a 20hp shot brought the quarter mile from a pathetic 17.2 to a 15.7! Stock, I would barely get into 3rd gear and with nitrous I was at the top of 3rd going thru the traps. A 20hp shot will give you about 6 minutes of use and nitrous can cost anywhere from $25-$60 for a 10 lb. refill. If you need more "long lasting" mods, the timing bump and a ducting hose from the bottom of the front bumper to the bottom of the air box will work too. A clogged cat can make a dramatic difference in power.....nothing a punch can not take care of! Now I know a lot of people are like...oh its bad for the enviroment, but if your gas mileage goes up 5mpg then how bad is it really?
hakosuka86
to what degrees do I adjust the timing on the s14?? which cam do i exchange out? the Exhaust one for an Intake one???does it matter which year Ka24de it comes from??
how can i actually wire up a N60 maf i got one from the Junkyard!
Bigvinnie
Ther should be a write up here on NICO for the N60/N62 wire up if you can't find it I will photo copy the the wiring diagram.Make sure that you have an ECU tune or an SAFC to use the N60 MAF.
