4drmadness wrote:Hey guys should i change my spark plugs? If so would you recommend the NGK ones? I have heard of people getting oil leak in their 6th cylinder. could someone enlighten me on that issue. changing spark plugs wont really help the oil leak right? the people who change spark plugs often, please let me know why you guys do it. thanks for your help.
Replacing spark plugs would not help with any kind of an oil leak. If the leak is within the engine, then it will still be there. And if the leak is in the seal around the spark plug hole, then its still going to be there, but should not enter the combustion chamber as the plug seals against the motor.
Recommended plugs are the NGK double platinum. The IX iridium plugs from NGK are single iridium (standard ground). The G35, as well as most modern cars, use coil packs. This type of ignition system creates 2 sparks. One in each direction. As a result, in order to get maximum life from the plugs, both electrodes need to be made of a hard metal, otherwise the ground will simply wear too fast to keep the plug lasting as long as it should. Denso makes an iridium plug that uses a center iridium electrode and a platinum ground. NGK makes these but haven't been importing them. That may change soon as it sounds like the G37 is using NGK's iridium plug with platinum ground.
