what are and how to install RCAs into a 2009 versa S stock deck
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
'09 Versa Hatch S
Car: '09 Versa Hatch S
please help, im stumbling on the RCA part of the sub/amp install
hiimjered
Car: '08 SL CVT
When wiring an amp to the stock versa stereo (or pretty much any stock stereo in any car) you have two options: 1. you can get an amplifier with speaker-level inputs or 2. you can buy and install a line-output converter.
Either way you will want to connect to the appropriate output wires in the back of the stereo. Wiring color information is available from the shop manual (you can find a downloadable version somewhere on the site.)
If you are hooking up a subwoofer, you will want to splice a connection to one of the speaker outputs (probably one of the rear outputs) without permanently separating it. You can use a splice clip, or you can twist and solder the wire together.
If you are using and amp and new speakers to replace the stock door speakers, you can simply clip the appropriate wires and hook up your own to run either to the amp or to the converter. Then you get to run the output wires from the amp to the new door speakers.
Either way it will take quite a while to pull all of the appropriate plastic to hide all of the wiring. I assume you've already run the power wires from the amp and remembered to hook a fuse as close to the battery as possible on the power feed wire. One more consideration is that you should run the signal wires somewhere other than next to the power wires. Sometimes the induction from the power wire can distort the signal if the wires are too close together.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Are you referring to RCA cables?
Return to “Versa Technical Discussions”
