Nameless EJ6 wrote:I've been doing some research.. but so far all I've found that is needed from the clip is:
- engine/transmission (the whole swap)- harness/ecu- intercooler + piping- mounts/brackets- radiator- small part of dash harness
Is that it? Are there any other little electrical components etc that is needed?
wga240 wrote:Let's see I've used a few pieces of the interior harness, the RB fuel pump, RB swaybar (modified of course), RB downpipe and cat, tons of bolts and nuts, a few relays, and probably some other stuff I'm forgetting, all in addition to what you mentioned above.
spec-v5150 wrote:I am just curious as to why you chose the RB fuel pump over a walbro?? Does it flow better. What mods needed to be done to get it to work???
Somehow I lost my 2 ignition relays for the RB20 ECU harness, so I stole 2 relays from the R32 fuse boxNameless EJ6 wrote:What are you using the relays for?
