what and where does this wire connect to ?
pungkiteater_671
http://i130.photobucket.com/al...8.jpg
just finsied my ka swap and this is the only wire that is left its the long orange one what is it and where does it belong ??
thanks
AZ89two4Tsx
Here's the pic for you. I have no idea where that goes.
pungkiteater_671
lol thanks alot bro !!!
truepinoy
Car: 240sx 1990
is it a thick heavy gauge wire? if so then it could just be an extra ground cable......other than that idk..
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
Um lol, thats def not a wire. It is a breather hose for the transmission there is supposed to be a bracket that holds it to one of the top bellhouing bolts.
pungkiteater_671
yes it is it even has the ground connector at the end
truepinoy wrote:is it a thick heavy gauge wire? if so then it could just be an extra ground cable......other than that idk..
kouki munster
Car: 97 base 240
pungkiteater_671 wrote:yes it is it even has the ground connector at the end
No its not, I have 2 5 speed trannys sitting in the floor of my work shop(not for sale) and have pulled countless more, and I can say with 100% confidence that that is the transmission vent hose and that it bolts down under one of the top bellhousing bolts
nightsauce
Car: 1991 Nissan 240SX S13 hatch RIP
1992 Nissan 240S S13 hatch :D
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
yup, it's a vent hose. It should have an inverted "u" shaped metal tube end with a flange that secures it to the top of bellhousing.
pungkiteater_671
OK THANKS
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
wow.
REALLY?!
and you had the audacity to dispute what the CORRECT people were saying?
its CLEARLY not a wire dude. maybe you shouldnt be working on your car alone, no joking here. find a friend who has good common sense and an IQ above "potato" and have him help you out homie
pungkiteater_671
well why wont you lick a d!ck b**** ! obviously im new to this s*** and this is my first swap and i was just clueless because it had a ground connector
people like u pissed me off sorry Mr know all tell me if this was ur first swap and had no previous experience on building a car u would be f***in asking questions
go bash on someone elses thread fagg
Modified by pungkiteater_671 at 7:54 PM 12/24/2009
Magnum375 Jr.
Car: 1989 Nissan 240sx Hatchback
Dude, what he is saying, dont go double guessing, and saying its a wire, when its a tubeeeee....I also have never worked on them, and I asked a ton of questions, but I dont doubt the people that have done numerous swaps, when they give me advice.....You asked a question, you got an answer, backed by the masses, and you questioned....how did you expect people to react, its NICO man, get used to it.
mrgreeneyes
Car: ///M5
i merely suggested that you find guidance and consultation in a person within your group of friends that has common sense and car knowledge enough to the point that you would be able to complete such a complex task as a motor swap, without having to question what a pink tube is, by calling it a wire "with a ground connector"
and when PINOY asked if it was a "big wire with a ground connector, possibly a ground" and you said "yes" then that implies clearly that you disagree with the other people who told you it was a TUBE.
carry on with your swap, and dont use your WHOLE vocab in one post next time please
pungkiteater_671
i wasnt double guessing what people were saying i was agreeing with true pinoy cause he asked if it was a wire and i said yah cause i thought it was and i didnt go on after i posted that and saw all of the post saying its was a tube so i went ahead and said thanks
Magnum375 Jr. wrote:Dude, what he is saying, dont go double guessing, and saying its a wire, when its a tubeeeee....I also have never worked on them, and I asked a ton of questions, but I dont doubt the people that have done numerous swaps, when they give me advice.....You asked a question, you got an answer, backed by the masses, and you questioned....how did you expect people to react, its NICO man, get used to it.
pungkiteater_671
much more better explanation
fyi got no freinds that are into 240s all hondas and the only one that can help me out is always busy and im done with my swap that was the last thing that was left out hanging so i went ahead and ask what it was and where it went cause i had no clue ...
but anyways thanks for the advice people and merry christmas eve
mrgreeneyes wrote: i merely suggested that you find guidance and consultation in a person within your group of friends that has common sense and car knowledge enough to the point that you would be able to complete such a complex task as a motor swap, without having to question what a pink tube is, by calling it a wire "with a ground connector"
Modified by pungkiteater_671 at 8:11 PM 12/24/2009
