Ryan_V wrote: I changed the oil and everytime I've checked it, I don't smell gas so that's great!
My idle is still between 1200-1400rpm so something is wrong there. I haven't tried adjusting the idle manually at the TB yet....I actually think that even if I did adjust the idle manually it would work it's way back up...
Someone else adjusted their idle and it came right back up too...
the throttle body should be closed all the way when your foot is off the gas pedal. all air allowed into the engine during idle should go through the IACV and all the adjustments should be made there. the FSM tells you how to do it, but basically you just turn one philps screw and you're all set.
