what am i missing
240SXedUp
What else should be on the list. What shouldnt. Any suggestions.
  • clutch/flywheel
  • port & polish
  • cams and gears
  • pistons, rings, and rods
  • turbo (dunno what trim)
  • oil pump, oil cooler
  • injectors, fuel pump, FPR
  • boost controller
  • 75-100 shot nitrous
As you can see, this is a basic list, no trims or sizes. Just a blueprint for the future
red240ne
Car: mmm...donuts
what are you going for? 400hp beast or just a cheap setup?
erich
Turbo manifold?Main bearings.ARP main studs & head studs.
Spazum888
Type R cell phone holder
4felix20
Car: Emerald Blue S14
intercooler...wastegate..bov. some piping (intake, downpipe) maybe a fuel rail depending on injector size.
nitrous? keep it basic and simple until after you get the turbo set up. i'd focus only on turbo essentials first. you could even wait on the pistons, rings and rods until after the turbo is set in.
turbo. then build the low end. then get nitrous. you may not even want nitrous and spend that money on other stuff like electronics for tuning.
cosmo
240SXedUp wrote:[*]cams and gears[*]oil pump, oil cooler
you used to be a Honda guy didn't you?
240SXedUp
No, all ive ever owned is a 240. What is ricey about camshafts and gears? And sorry, i forgot to add all the turbo stuff. I was just puting the BOV, boost controller, wastegate, intercooler and all plumbing, etc etc, with the turbo part.
cosmo
240SXedUp wrote: What is ricey about camshafts and gears?
I didn't say it was ricey. Its just that up to that point you were asking about a turbo setup, while the list you had didn't have very many turbo required parts, and cams and gears were such a priority that you left out other important stuff
