What am i missing? and racecar pics 56k*
l8apex
Car: buncha vws 98 240,
Ok, so here is the rest of my intro and my current swap parts list
this is the car that I will be dropping my rb into come fall. These are old pics, shes comeing out of paint this next weekIt is currently home to a fairly good s15 sr20det set up, but im looking more power and tq
here is current swap partslist, please feel free offer suggestions.r33 rb26dett full swap-5k(=/-)? still looking, probibbly more twards 7k)rb25 transmission-500$/1000$?mckinney RB26DETT KIT, motor mounts-$600.00 tophat CORE rb26 mounts 375$mckinney s14/rb harness service-350$? ( think thats what i saw)mckinney s14/rb driveshaft 525$ (may be cheaper locally) tophat driveshaft-500$ (also looking at local shopsClutch (BLITZ ACTIVE 1640.00$) LOTS OUT THERE FOR LESSAEM EMS (TBA)AEROMOTIVEFUEL PUMP, 700 EFI ELE PUMP (RED) 280.99$MOUNTING KIT 27.01$FILTER, IN-LINE AN-10 SIZE (10 MICRON 71.60$FILTER, IN-LINE AN-10 SIZE (100 MICRON 86.94$FUEL PRESSURE REGULATOR- 150$ARP HEADSTUDS (PART #?)COMETIC HEADGASKET (.054) 138.15$GREDDY INTAKE MANIFOLD 547.50$HKS Adjustable Cam Gear (INTAKE AND EXHAUST)140.25$ EACH
I would also like to upgrade the twins, so I would like some recomend input on that as well.
The exh mani's wil be custom fabbed along with the entire exhaust system
Thanks for your imput
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
nice cage!!!
gawdzilla
Car: none
you're probably gonna need a seat too
if you're fabbing the exh manifold, i'd get a single turbo.
l8apex
I considered going single, but i like the quick spool of a twin setup.
and the bling-bling factor
dsc4130
dude i just wanted to say i love your sig. that is the best one ive seen
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
1995 Nissan Skyline GT-R V-Spec Midnight Purple
1990 Nissan Laurel Club S Turbo Two Tone Pearl
dsc4130 wrote:dude i just wanted to say i love your sig. that is the best one ive seen
LOL...that was funny.
Hey! I'm an Acura!
GOLDEN
l8apex
idn where i got it from, but i love it
rustbucket
Car: '90 s13 RB25DET SII
driveshaftshop.com has better deal than anyone I could find, $475 for ALUMINUM drive shaft, all you have to do is send them your measurements.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I was just curious why you have two sets of motor mounts listed?? Are you still contemplating one or the other?
Go with a custom driveshaft w/Z32 yolk and it would probably be best to wait and be sure of the length necessary. A custom DS is cheap ($200) and a shop can usually make one in an afternoon if they're not busy.
How much boost are you planning on running? If <20psi, I would not bother with the head gasket or head studs. If you remove the head and replace the OEM gasket with a steel one, you NEED to get both faces machined flat before reassembly. Trust me on that one.
Where did you find the Greddy IM for <$550?
PowerFC might be a cheaper alternative to the EMS although I hear the EMS is top of the line. Just depends on your power goals and need for fuel tuning etc. I'm assuming by the cage that the EMS will be a better fit
What steering wheel spacer/hub are you using? How is the fitment/quality? I'm tall and need to extend the wheel towards me so I can reach and not hit my head on the ceiling while I'm driving.
l8apex
/I am still debating on the mounts
the boost i run depends on the turbos i decide to run
as for my prices, i am a dealer, those are my prices, and i shouldent have listed them but, oh well
I love the aem ems, its my baby
I was useing a nardi six-inch ajustable extention, but now i am useing a nrg quick releses and a deep dish momo wheel
Darius
This might help in the turbo search a bit:
http://www.skylinesaustralia.c...93880
Obviously need to check the compressor maps to verify efficiency and that you're not running outside the surge limit.
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
If you get an RB26DETT , DO NOT ruin the motor by going to single turbo, thats retarded. Keep two turbos on that motor, it will be more responsive and you will have a better power band. People seem to not understand that. If you want more power, upgrade the those turbos at the same time. Dont ever go single turbo on an RB26DETT unless your going anywhere other than straight, even then, the fast RB motors utilize twins anyways.
takaramotors
Car: Nissan Skyline PCG10 GTR
TOp hat mounts from me 340 shipped as well our wiring services 350 as well s-14 -Rb26
gawdzilla
Car: none
thats a myth. the only twin setup that gives you more response is a sequential twin setup, and the 26 is not. half of the exhaust spooling turbos that can produce half the power, plus you add in your piping loss, and you are slightly worse off than a single. the truth is you can make good useable power with either a twin or single setup. i highly doubt the allegedy great response of the 26 is because of the twins, and more b/c of the itbs. the reason people say the car loses response after going single is b/c they step up to a huge turbo. if you got two big twins you would feel the same effect. its all about turbo choice, not single or twin. running twins does have that coolness factor though, but it is not advantageous. if you look at all the racing skylines, drag or road race, its really a toss up between twin or single.
Kansei240sx wrote:If you get an RB26DETT , DO NOT ruin the motor by going to single turbo, thats retarded. Keep two turbos on that motor, it will be more responsive and you will have a better power band. People seem to not understand that. If you want more power, upgrade the those turbos at the same time. Dont ever go single turbo on an RB26DETT unless your going anywhere other than straight, even then, the fast RB motors utilize twins anyways.
Modified by gawdzilla at 7:31 PM 7/5/2006
SeVa-S13
Car: '05 GTO 6spd
I know the general conception is that twin turbos = instant spool/response, but it's just not universally true. In a parallel setup, such as the RB26, twin turbos offer no advantage over a bigger single of similar proportions to the smaller two, if combined. Response and power have to do with turbo selection, not some magical attribute determined by the number of snails hanging off your exhaust manifold. A properly chosen single can provide just as much power and response, if not more, than any parallel twin selection -- and do so cheaper, and more simply.
Imissmyturbo
Car: Car's, Turbo's, sking
Save yourself alot of money and get a 2jz. RB26's are great motors but are currently selling for twice what they are worth.
