What alternators are (relatively) compatible?
BenKenobi
Car: 1989 240SX
The alt in my car died Sunday, and I'm hoping to find a replacement in a junkyard. Unfortunately, there are no S13s at my local pull a part.
I'm looking at other vehicles that have the KA24E, but I'm not 100% sure on compatibility. So far, the 90-92 stanza is looking like a NO.
I'd imagine whatever I find will require me to swap out the pulley.
upsdude
Car: '95 zenki
i think you can use a nissan quest alternator...but it requires some modding at the bracket...but i can't confirm this 100%
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
i use autozone's website and compare part numbers
BenKenobi
Car: 1989 240SX
Right. I did something similar using rockauto's catalog. You can click on the part number and it'll bring up a list of other vehicles that share that part.
Unfortunately, it tells me that only:
NISSAN 240SX (1989 - 1993)NISSAN 240SX LE (1991 - 1992)NISSAN 240SX SE (1989 - 1994)
share it. Of course, I'm betting that's out of the box. I was hoping there'd be some way to swap out a pulley or something easy.
I may just suck it up and shell out the $100 for a new one.
... or learn how to rebuild one
What confuses me is I called a place that rebuilds alts. They wanted $160 to do it though! How can it cost me $160 to rebuild something that costs $100 remanufactured?
BenKenobi
Car: 1989 240SX
So I think my plan of attack is going to be to remove the alternator, check the brushes. If they look badly worn, I'll replace them and see if that helps. If not, I'll just replace the whole thing.
BenKenobi
Car: 1989 240SX
Finally got the thing off... and I noticed something odd.
There was an "E" (exciter?) marked on the rear cover, and a corresponding hole, but no post/nut for a wire. There was also a wire with a ring terminal on the end near the alt that was not connected to it.
Could this be the problem?
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
BenKenobi wrote:There was also a wire with a ring terminal on the end near the alt that was not connected to it.
Sounds like your ground...
BenKenobi
Car: 1989 240SX
Well there was the "BAT" terminal. That had a wire hooked up to it.
PyR0NiAk
Take that wire with the ring terminal and hook it up to where another ground is in your engine bay. (Such as a thick black wire)
BenKenobi
Car: 1989 240SX
Here's the thing. That wire is wrapped up with other wires. It comes out of the wrapping right by the alt and has very little room to move around.
Zooming in on the right side, you can see where the "BAT" terminal is and directly below it is the "E" one... This one doesn't seem to have a post either.
The problems onset pretty quickly. I first start noticing at 1am on Saturday and by noon Sunday I was out of commission.
I suppose bringing it to Autozone for testing would be the next step.
*edit* ah-ha! The picture from Autozone's website shows a SCREW in the hole near the E. I think I've got this mystery solved.
Modified by BenKenobi at 3:47 PM 11/9/2009
PyR0NiAk
Glad you solved it.
BenKenobi
Car: 1989 240SX
Weird I saw a reply in my email saying that the E was a ground... It, in fact, is.
BAT however is for a constant 12v from the battery. I wound up just running a new wire, but wonder if I should put an in-line fuse on it just in case... and if so, what amperage?
PyR0NiAk
Told you it was the ground...
