what all can i remove from my ka24de as far as emission stuff goes?
austins-13
Car: 93 nissan 240sx hatchback
ok so im rebuliding the head on my ka and i was wondering what all i could remove as far as emmission stuff goes and would it even be worth it? i dont really care if it dosent pass, because living in oklahoma i dont need it to.
gumby74
I recently rebuilt a DE for my hatch. I removed the EGR and the BPT valves. I made some block off plates out of some 1/4" aluminum plate I had laying around. I also eliminated the air tubes (EGR bypass tube and the AIV tube) that bolt into the header.Keep track of the vacuum lines so as to know which ones to cap and which ones to keep pressurized. The engine runs and idles great, and not throwing any codes.At some point I will pick up a second intake manifold and do a proper shaving and welding of unused vacuum and water ports. Maybe even do some wire tucking at that point also.
sean@z1
Car: 1993 240sx
If you do not have to worry about emissions! I removed the charcole canister The EGR block off plates The air box was ripped up just leave the bracket cause it is your factory SMIC for the SR and CA bracket. I did a test pipe as well
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
emissions stuff!.....whats that!....all my emissions stuff is gone off of my car..codes..i dont look anyways...runs fine..and less BS..allso will benifit the cleanup of the speghetti vacume lines.
Shabbernigdo
only emmisions i have left on my car is the CAT and the only vacuum line i have left is the one that goes to the FPR.
cornuts
Car: 91 nissan 240sx
hey bro i see u removed the charcole canister i did too but i have a hose that turns into a hard line and it runs to the firewall and into the right side of the bay and runs down..? what is it or what did u do with it?
Shabbernigdo
cornuts wrote:hey bro i see u removed the charcole canister i did too but i have a hose that turns into a hard line and it runs to the firewall and into the right side of the bay and runs down..? what is it or what did u do with it?
thats the vent line that come up from your gas tank. some people say cap it some say vent it . Personally i ran a line down under my car to let it vent the fumes away from my engine bay.
cornuts
i see thanks
gingerbredman
Car: 93 SE hatch, ~260k miles on the clock, 15" Enkei 92s, still stock. 2009 Sonata bouncing on Eibachs.
Yeah, remove that plate on the back of the head that has those 2 plugs. Remove the EGR and the UFO thing attached to it, etc. remove all vacuum hoses but make sure you've got a vac. hose coming off the bottom of the manifold to the fuel pressure regulator, or else it won't run. The other Idle control thing you actually don't even interfere with in the whole process so no worries. I've got some pics, I just need to download them to the comp, I will 2morrow if you want.
Oh, there's a OEM Nissan plug for the EGR and aicv or w/e it was. A heck of a lot better than JB Weld lol sounds like a shotgun when you blow the gob of JB out
