What aftermarket parts to put while I'm doing the SR swap
bob marley
I ordered a redtop SR and it's going in my 91 fastback. Since cars are my hobby, I would like to use the bare minimum aftermarket parts so I can later upgrade in stages. Also, I don't want to spend too much money right away (you never know if something will go wrong). However, this car is my daily driver so I would like it to be reliable. What aftermarket parts do you recommend I get? I'm also doing this to get an idea of how much I will be spending. BTW, I live in Florida, so its always HOT.
Here is what I was thinking
Radiator - Koyo Aluminum ($350)Fan - Flex-a-lite dual 12" ($230)Exhaust - Apex'i GT (I will eventually uprade the turbo) ($500)Fuel Pump - Walbro 255 ($120)Extra hoses (~$100?)
If the engine mounts and clutch are bad, then I'll get
Motor mounts - Nismo ($300)Clutch - SPEC stage 2 ($320)
Anything else? Any comments on the parts I've chosen?
Johann
SWIFT_DRIFT
a downpipe for sure avg. $150-200
nismodave
BUY THE MOTOR AND transmission MOUNTS!!!!!
Im regretting not doing it now .....too much flex on motor amd shake on transmission.....
As soon as I can Im gonna replace mine.
IvanS13
Car: *** & Titties
Would you recommend me gettin a new radiator, fans, and motor/transmission mounts over a FMIC?
nismodave
IvanS13 wrote:Would you recommend me gettin a new radiator, fans, and motor/transmission mounts over a FMIC?
Tough call......Im gonna say do the fmic....Its easier to put in the intercooler when everything is out.
The radiator and fans can go in later......
Do the mounts if you can.....but if they are ok and you dont have the cake........leave the stock ones in.
bob marley
Ok, I think I might go with the Nismo motor mounts and the downpipe (since most likely I won't get a downpipe with the clip)
It's probably easier to go with a FMIC instead of a radiator when you are doing the swap because everything is out. The radiator is always easy to do. The reason I am doing the radiator now is because I hear a lot about the engines overheating in Florida. I don't mind taking the front off, etc to install the FMIC later.
The running list so far is:
Radiator - Koyo Aluminum ($350)Fan - Flex-a-lite dual 12" ($230)Exhaust - Apex'i GT (I will eventually uprade the turbo) ($500)Fuel Pump - Walbro 255 ($120)Extra hoses (~$100?)Motor mounts - Nismo ($300)Clutch - SPEC stage 2 ($320)Downpipe - Blitz ($180)
Total: $2100
Gezz, thats a bit more than I wanted to spend. Hmmm. Anything else?
Thanks,Johann
nismodave
Ummmmm.....
Boost controller.......nice to have when compettion increases
Blow off valve.......saves your turbo.
Good plugs......or at least new ones.
Good oil......Mobil one or royal purple.
Boost gauge......good to have.
Walboro fuel pump.........get that fuel to that thirsty motor.
High flow cat or test pipe........frees up hp
Greddy 02 sensor pipe........good for 10hp or so......
That should keep you broke....like me :D
bob marley
nismodave wrote:Ummmmm.....
Gezz man, I'm gonna have to get my shins broken to pay for this car. And then I won't even be able to drive it. :D
I already got the oil and plugs taken care of, and the fuel pump is on the list. I think I'll hold off on the rest of stuff so I can afford food :D
Thanks, Johann
ucfz31s13
Car: Business/Networking/Web
Blah...you're supposed to be feeding your car, not you! lol...
:P
Gotta keep her happy you know...and just like a women, they can never get enough!
lataz
z
bob marley
DiscreetSpeed wrote:Blah...you're supposed to be feeding your car, not you! lol...
:P
lataz
z
LOL. I guess I can get FMIC and Boost Controller. I mean, its not like I have to eat for a few weeks. Thats just being selfish. jk
Johann
teriyakibroccoli
go down to your local supermarket, get a huge box of cup-o-noodles... they're like $20 for a pack of 400.(kidding, but its a lot of ****.)
Cyberkreig
Car: 1993 Nissan 240SX SR
cheap soup mix keeps me alive.. and my job doing pizza delivery, no benifits, no raises in over a year of work.. but free icecream and pizza!
the_invisible
good call on the radiator and new hoses. They will only make your car more reliable. BOV and intercooler also go a long way in maintaining your car. cooler temperature, without a doubt, is good for the car.freeer flowing exhaust reduces temperature.
big jon's 240
Car: uh....football, cars, and um, cars!
bob marley wrote:If the engine mounts and clutch are bad, then I'll get
I would take the clutch off of the "if its bad" list, you will thank yourself for doing it while the motor is out of the car.
IvanS13
Car: *** & Titties
Hehehe, its all about the cup-o-noodles. Helps me get them car mods!
bob marley
teriyakibroccoli wrote:go down to your local supermarket, get a huge box of cup-o-noodles... they're like $20 for a pack of 400.(kidding, but its a lot of ****.)
lol. True. Us rich fold prefer Ramen Noodles (heh, around the same price)
Big John's 240 - Yea, I think I'll change the clutch while its out.
Thanks, Johann
hokiruu
Car: 2012 INFINITI M37X Platinum Graphite
'95 240sx/s14 SR20DET (in 2000) SOLD
I started on a similar plan... and now its gone from bare minumum to everything basic and a few extra toys.*denotes "do it!"*water pump*clutch*Nismo mounts*fuel pump*intake*FMIC*downpipe*straight pipe*plugs*z32 fuel filter*boost gauge
Zaxx84
Check out the Greddy oil filter relocation kit....$150 makes your life a hell of a lot easier, and it's easy as pie to install when your motor is out of the car still...
hokiruu
yeah, and like I said, it will keep your engine/oil pan cleaner in the long run
