what adjustable fuel pressure regulators would fit?
S14tat
Car: 2007 FX35
1994 Acura NSX
1996 Honda Accord coupe
1995 S14 KA-T *sold*
yeah i'm afraid my fuel pressure regulator has taken a turn for the worse. its reading 38psi with the vac hooked up and 38 psi with the vac unhooked. so its most likely done.
instead of replacing it with another stock one, i'd rather get an adjustable one since with the walbro pump it would usually read around 4-5 psi higher then stock pressure at idle. so i would like to tune that out.
so i would like to know what would fit with NO modifications. and also do you guys think its the FPR? or could it be the fuel pump?
thanks
Chezedik
Car: 1991 Nissan 240sx
Nismo! it is built just like stock, but with a bolt on the top to adjust it.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Problem is, the NISMO Adj. FPR DOES NOT fit the stock rail...it will bolt on, but hits the head!
It was made for the SR rail, which has the FPR at a different angle.
You have 2 options:
1) Make a bracket to hold it in place...it seals with an o-ring, so it can sit anyway you like...but you need to bolt it in place so that fuel pressure does not pop it out of the rail.
2) Get an universal 1:1 ratio adj. FPR...and use an adapter like so:
http://www.store.yahoo.com/pha....html
- Brian
crzycav86
Car: 93 Nissan 240SX KAT
I installed this one last tuesday: http://cgi.ebay.com/ebaymotors...ZWD1V
I was surprised that it actually fit. I just had to buy an o-ring, two longer bolts and two washers. No leaks that I'm aware of. But I haven't tested it out very much.
Can't beat the ebay price either.
S14tat
Car: 2007 FX35
1994 Acura NSX
thanks for hte reply guys, but it was just a false alarm. i tried testing it again and i pulled out a different hose, and the fuel pressure shot straight up to 50 psi. so i was like *whew*
Chezedik
Cav, that is basically the same one I have except it came in a Megan box (Counterfiet parts Megan, yes), and it worked well? I haven't installed mine yet, but that is good to hear. Are you using it with an FMU?
crzycav86
no. i'm using it with my 370's.
i actually put my worries to rest when i came across another nico member who had it on his car with no issues.
