what about the other LS series engines?
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
VVT, what engine uses VVT? Maybe something new thats on its way out, but none that I have heard of.
Not a fan of VVT at all
drewhenderson13
Car: 96 ford mustang gt, 98 chevy s-10
actually i believe its on its way in. either teh newest ones have it or their coming out with it soon.
WDRacing
Great thread...lots of good info. Whats the market value of the LQ these days? They were $1200 for the motor alone a few months back, but that was from an engine depot.
WD
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
no one mentioned the fwd all aluminum 5.3.
ls3 i think they are called?
from the monte's and such.
hannibal
Car: Red Line to Glenmont
^ those are LS4's. The 2008 C6 has the LS3...
I believe the Trailblazer had the only aluminum 5.3 truck motor. And the Trailblazer SS has an LS2. I read the intake manifolds are interchangable, but the truck intakes are TALL.
Theres a new 6.2 L aluminum motor in the newest Escalade...
MrPresidentQ45
Car: 1999 Q45 1999 G20 1978 KZ1000 LTD
The main issue you'll run into with the smaller LQ motors is head selection due to dore size, though most of the LS1 stuff fits. If you go LQ and not a 6.0, try for a 5.3 as it appears to be the most common (in my area anyway). I'm sure someone will notice, but as I've said in other threads, the 6.2 heads are available from GMPP and if you check the flow numbers, they are the best bang for the buck this side of an aftermaket ported head. The downside is, they only fit the 4.0 inch bore 6.0 and 6.2 motors. I just checked and there's an LQ4 on ebay for 1,700, motor only (no trans). The LQ4 is the low compression motor, the LQ9 is 10:1. Search LQ4 in Wikipedia and you'll get a ton of specs.
drewhenderson13
another issue is the front accesories. they for sure wont fit under the hood of anything but the trucks. you have to us f-body or similar accesories to fit them in a car.
Shift_Kouki
Car: 95 Nissan 240SX SE
MrPresidentQ45 wrote:The main issue you'll run into with the smaller LQ motors is head selection due to dore size, though most of the LS1 stuff fits. If you go LQ and not a 6.0, try for a 5.3 as it appears to be the most common (in my area anyway). I'm sure someone will notice, but as I've said in other threads, the 6.2 heads are available from GMPP and if you check the flow numbers, they are the best bang for the buck this side of an aftermaket ported head. The downside is, they only fit the 4.0 inch bore 6.0 and 6.2 motors. I just checked and there's an LQ4 on ebay for 1,700, motor only (no trans). The LQ4 is the low compression motor, the LQ9 is 10:1. Search LQ4 in Wikipedia and you'll get a ton of specs.
Some of the HP numbers when those GMPP heads are dropped onto 6.0 motors are freaking nuts, especially when given a nice cam and supporting valve train upgrades.
Like 550 wheel HP right out of the box. For no power adders, and not boring / stroking the motor... its the best bolt on I've ever heard of.
Toshima
Car: 93 240sx, 93 sc300(m/t)
I found a 1998 5.7L Vortec L31 block, and a ls1 head. Will this work? Everything bolting up. Becase I read that the L31 is the last production Generation I small-block. But can I still use Ls parts on it?
WDRacing
Nope
drewhenderson13
the ls engines in the trucks were called vortecs but im not sure why, i dont think the head design is really vortec. the heads are the only thing that make a gen 1 a vortech btw. i believe it has to do with offset valves that suposidly swirl the air/fuel... anyway, the ls vortecs are not the same as the gen 1 vortecs. as far as i know there is nothing interchangible between the two at all.
Joe
cnichols wrote:
There is no variable valve timing. I think you're referring to displacement on demand.
actually he is kinda right just off a generation.
the Ls3 and L92 engines (5th gen) have variable valve timing via the use of a cam phaser.
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
Yeah, I found it after I posted...but didn't bother to change it because he annoys me and I'm lazy.
Bmxandcars
Car: '92 240sx hatch
Can an lsx computer be used for a manual transmission swap on these engines? Truck injector sizes? or do you need an car intake? etc.
Return to “Hybrids”
