bruinbear714 wrote:Some guy I met at a meet last week is running 10psi on his KA, with STOCK INTERNALS. He's put well over 50,000 miles on it with the turbo already.
That just goes to show that the stock internals can handle 10psi for quite a lengthy mile, but only if you're careful and drive responsibly
Actually, the stress you have to worry about the most with rod longetivity is tensile stress. This is the stress acheived from the piston's upward momentum pulling up on the rod. Tensile stress is the stress that causes fatigue, so you want to try and make sure the rods can handle this. And the engine speed is really what determines how much tensile stress a given piston/rod combo will have. Compressive stress can damage the rods, but not over time. It will not fatigue the rods. It will give when it reaches a certain amount of compressive force. Just don't detonate and don't boost over the limits of the rods(which I doubt anyone has actually determined yet) and there is no reason why a KA or any motor for that matter would have problems boosting reliably for a long period of time...even with a moderate to high boost level.
