NightRiderQ45 wrote:Glad you were able to pep your car up some. I wanted to try the Iridiums plugs my last change, but I went ahead and put in the OEM plug. I plan on running the oem plugs for at least 100k. The cheaper V-Power NGK had 130k on them with NO missfire.
I agree, my last set of OEM plugs were in from 69000 miles til 203,000 miles {roughly 134,000 miles of use} and came out looking good.....no change in power or MPG by replacing with new set of OEMs......basically change plugs only when valve covers need resealing as there is no additional labor needed to do them at that time. At this rate, my Q will go to grave at 300,000 miles with only having the plugs changed 2x......following "the book" they would have been changed every 60,000 miles which is a total waste of time and money.....notice newer cars with same exact plug now specify over 100,000 miles between changes.
