I am pretty damn sure that the 300zx TT hubs do not work. But hey, don't hold me o that either1991S13 wrote:I know you can use the brakes off of a Q45, so Im assuming you can use Q45 hubs too.
Don't hold me to that though, Im just throwing it out there in case it is right.
EDIT: I see that Q45 hubs are the same as the z32 TT hubs, and after searching no one seemed to answer the question whether or not you can make those work on an S13.
wtf? that doesnt make sense...u can use q45 which is the same as z32 tt but u cant use z32 tt. ???vvaffle wrote:most definetly I think that you might be able to use q45 hubs which are supposedly the same as z32 TT hubs which I am almost that you can't use, but don't hold me to that either. I would like to know this as well...
if u use the s14 fronts i think u need the spindles too or the different bearings in it, i dont remember. i know s14 and z32 rears are direct swaps.TachyonS14 wrote:From what I've heard, you need S14 SE hubs up front and for the rear you can use S14 SE hubs or 300zx hubs. Not 100% sure, but that's what I've seen from reading around the forum.
I was making a joke about the vagueness of everyone's answers. guess it wasn't a very good joke. but trust sr_smith to know what he is talking about.so the only way to change the front to 5 lug is either s14 with all those parts or aftermarket hubs right?240DRFT wrote:wtf? that doesnt make sense...u can use q45 which is the same as z32 tt but u cant use z32 tt. ???
Technically speaking:The S14 and S13 front hubs are basically the same, minus the 4 and 5lug difference.You CAN use the S14 front hub only! and press an S13 bearing into it. The S13 and S14 bearing outer diameters are the same, it's the inner diameters that are different.vvaffle wrote:
