What 17" nissan/infiniti wheels will bolt right up to my 99 Q45t
GM991
Car: 1999 Q45
So I need to buy snow tires and I want to just get a set of 17 inch infiniti or nissan rims put the summer tires on those rims and use my origanal Q rims as the winter rims because they were pretty beat up by the last owner.I beleive the stock tires (summers/all season) are 225/50-17 and the rims are 17x7.5 +30 offset.
Any give me a list of nissan/infiniti 17x7.5 and an offset thats close and will work on my car?
thanks
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
the G35 and 350Z ones will work fine. Pretty much all the 5 bolt ones will.
GM991
Car: 1999 Q45
so pretty much any nissan/infiniti 17x7.5 rim will work??I thought the offsets were different on alot of them?
Rex
Car: None
GM991 wrote:... Any give me a list of nissan/infiniti 17x7.5 and an offset thats close and will work on my car?
thanks
Stay away from the newer (05 and up) M35/45 wheels, they're offset is too high.
G35 Sedan wheels will probably be your best bet ... and cheapest. I'm running a set of (F50) Q45 wheels, and other than being butt ugly brown, they work well. Offset on those may be a touch high (+40, I think), but with narrower winter tires, it shouldn't rub.
GM991
Car: 1999 Q45
what about 17" nissan maxium wheels??I just thought the nissan name would bring less money than Infiniti.
Also I might have a lead on a set of 17" wheels off a 350z. (they are the guys winter tire set up not the stock wheels) the guy said the rims are all the same size, but the rear tires are a little bigger. Will those bolt right up?
Rex
Car: None
GM991 wrote:what about 17" nissan maxium wheels??I just thought the nissan name would bring less money than Infiniti.
Maxima wheels would likely have a higher offset, but not so much that (skinny) winter tires would rub.
Non-OEM 350Z wheels "may" have lower offset (25-ish), but (again) not so much and issue with the skinnier winter tires.
All this is assuming you're going to run somethign like a 225/55/17 winter tire.
Remember, skinnier winter tires are better.
GM991
Car: 1999 Q45
would '03 G35 coupe automatic wheels fit right?
Rex
Car: None
GM991 wrote:would '03 G35 coupe automatic wheels fit right?
Assuming you're referring to the 17x7.5 +30 & 17x8.0 +33, then yes thye will.
GM991
Car: 1999 Q45
Is that that the stock wheel sizes on an 03 automatic sedan?The guy selling them said stock 03 wheels
GM991
Car: 1999 Q45
Anyone selling 17x7.5 wheels need a set
GM991
Car: 1999 Q45
I was going to run 225/50-17 (the stock size) for snows.
If the off set is less like 25 how will that effect the look/performace of the car? Tire Rubbing? would that happen going from the stock offset of 30 to 25 with the stock size tires??
How can I tell what the off set is on a set of rims anyways??
thanks
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
I think that Nissan and Infiniti rims have both the size and the offset stamped on the inside of the wheel, so anyone sellng a set can look inside the wheel and tell you.
Rex
Car: None
GM991 wrote:I was going to run 225/50-17 (the stock size) for snows.
thanks
That's a good size for snow tires. The skinnier the better ... to a point. You just don't want the tires sittign on top of the snow.
Lower offset (especially on a wider wheel) will have "everything" sitting farther out. With "snow widths" it's unlikely even a 25 offset would create any fender rubbing issues.
Any "decent" wheel should have the offset stamped on the wheel/hub somewhere. Look for an oval with a stamped value or the letters ET with a number next to them. Oddly enough, it's easier to find the number if you "know" what a realistic value is.
GM991
Car: 1999 Q45
coolthanks for the info guys..
jamestgk
Car: 2003 M45
i got 18 inch 03 m45 rims and tires?????????????? see my post
szh
Car: 2018 Tesla Model 3.
jamestgk wrote:i got 18 inch 03 m45 rims and tires?????????????? see my post
The OEM 2003 M45 wheels (18x7.5 with a 35mm offset) should work very well!
You can put a 245/45-18 tire on it for a good result.
Z
jamestgk
Car: 2003 M45
mine have mich mxm4 235/45r18 94V rated
i also have a set of 245/40z18, and 275/35z18
contisportcontact z rated extra load
szh
jamestgk wrote:mine have mich mxm4 235/45r18 94V rated
Will work, but a 245/45-18 has more of a tire selection available. On my 2003 M45, I use Goodyear Eagle F1 GS-D3 245/45-18 with a 100W load index.
jamestgk wrote:i also have a set of 245/40z18, and 275/35z18
The second one is too wide for a 7.5" rim. Very unsafe!
What is the load index shown on the side of the tire?
Z
jamestgk
Car: 2003 M45
i agree on the too wide i was just advising what i had
no load index listedmax load 1608lbs-on 245'smax load 1709lbs-on 275's
