What 02 sensor
unexpressedcolor
Ok heres the issue i just bought a full exhaust system the 02 sensor doesnt fit(to skinny) and i remeber wrighting down a 02 sensor model number that would fit and i found it on this forum, problem is i cant uses words like 02 in search (to small)
So i need a 02 sensor compatible and will also fit the bung size for my turbo outlet (which is a megan i belive)
tHANKS!
biglipzit
Car: sr20det S13 RHD 200SX
it is actually O2 not 02... and try using the word Oxygen Sensor if O2 is too small or O2 sensor is also longer than just O2
unexpressedcolor
i tried oxygen but thanks for the tip on the o2 i spaced on that
180fan
Car: 89 fastback
yeah check the sticky at the top of the sr board and then go to parts list.
