WG vacuum line
Frankenstien93
Car: Nissan 240sx SE
I was just wondering what hoses you guys use on your wg I have mine hooked from the wg to the compressor housing. (that will work right) but I just gets too hot and melts the hose I dont know if im just being stupid or is there special stuff I have to but because when it jumps from 8 to 15 psi thats fun and all but not very good
Frankenstien93
? anyone
steve s14
try using silicone hose, it can withstand higher temperatures. if that doesn't work, you might have to use this hose covered in a heat wrap.
Frankenstien93
thx ill try that
StylinMotors
We make the stuff you are looking for>
As a new Site Sponsor we even have a special going this week only.
Look here for details: zerothread?id=163337
Frankenstien93
one last question its ok to run from the WG right into the comp housing right? thats how i have it hooked up now but didnt get to test cuz i blew off an ic pipe
Tictakman
ya u want the reading from the compressor. i have mine like 3 inches from it but thats bc the nipple was already there. also, for the signal, u want to run the line to the side of the tial wg. the top should be left unplugged until u get a boost controller.
Zak
