I found it interesting that this was a GM proving ground yet the GM pickup was second worst.Jesda wrote:GM second worst. Toyota second best.
[youtube]http://www.youtube.com/watch?v=LFJI0tLMVpI[/youtube]
Still, of the trucks tested, I'd rather have the Ram or Titan. After spending a year with a Navigator, I absolutely believe that Ford's traction control is superior.
Absolutely agreed. The new Ram's my first choice for a brand new pickup, and the Titan a close second. Titan might be third if Ford had kept the F150 handsome rather than making it gaudy. If they put a Coyote derivative under the hood I may be willing to overlook the looks.Jesda wrote:Still, of the trucks tested, I'd rather have the Ram or Titan. After spending a year with a Navigator, I absolutely believe that Ford's traction control is superior.
That drives me NUTS. I was doing fine up a hill on ice in my friend's Lincoln when a truck (some kind of big dump truck) in front of us came to a complete stop. Everyone had to put their cars in reverse and take a dangerous and twisty alternate route.MinisterofDOOM wrote:Also, thanks, Mr. d*** in the Corolla who was going 10mph UPHILL and forced me to bleed off ALL of my 60mph of momentum and thus get stuck in the heavy wet snow. You're a real pal.
You'd be real surprised. A quick survey of TireRack will show you that the OE tire selections are often among the bestsellers for their respective cars. Now, that's a pretty weak example but I doubt anyone has done quantitative research on the subject.MinisterofDOOM wrote:I'm assuming they used factory tires. I wonder if things would be different if they tested the trucks with the same tires across the board. I've never liked that most tests, reviews, etc. use stock tires, as few people stay stock when replacing their tires. Most people buy cheap, a few others buy performance, but few buy the exact tire their car had when they bought it.
Tire rack, sure, but if you go buy tires at a brick and mortar store they've got the sales schpiel to throw at you; everyone I know who isn't a car person tends to go for whatever the shop convinces them is "cheap but good." A lot different from tire rack where you tell it what car you drive and it tells you what tires it came with as well as similar options.Urabus GodofTraction wrote:You'd be real surprised. A quick survey of TireRack will show you that the OE tire selections are often among the bestsellers for their respective cars. Now, that's a pretty weak example but I doubt anyone has done quantitative research on the subject.
I've purchased brick and mortar tires twice. Both times, the sales monkey immediately suggested the OE tires. In my experience, OE tires have always been very expensive, and I'm sure a large chunk of that is markup.MinisterofDOOM wrote:Tire rack, sure, but if you go buy tires at a brick and mortar store they've got the sales schpiel to throw at you; everyone I know who isn't a car person tends to go for whatever the shop convinces them is "cheap but good." A lot different from tire rack where you tell it what car you drive and it tells you what tires it came with as well as similar options.Urabus GodofTraction wrote:You'd be real surprised. A quick survey of TireRack will show you that the OE tire selections are often among the bestsellers for their respective cars. Now, that's a pretty weak example but I doubt anyone has done quantitative research on the subject.
You may still be right...I could be mistaken...but in my experience physical tire shops like to sell whatever they've got going on, not what the car actually came with off the lot.
