Ryan Heo wrote:Can I use RTV silicon for spark plug tube seal?If it can be worked, where do I put the RVT ?
coolhand wrote:Try the dealer set. they work much better.
I thought you had learned your lesson with the transmission about taking the cheap way out. I'm not trying to be an ***, but you get what you pay for. I always get OEM gaskets and seals from one of the sponsors when I am working on an engine or transmission. That's fine that you got the gaskets cheaper; but looking back, was it really worth it?
That being said, I can tell you have a passion for your car, and you are eager for as much knowledge as you can get.
I just think that you would have much better results if you slowed down, and did things the proper way the first time. To me, it seems that you have taken on a massive amount of problem/projects in a very short period of time. I understand that you want to solve all the problems as economically as possible, but you need to look at how you are doing that, and if there are any tangible savings.
I apologize for lecturing.
