Aries »
https://forums.nicoclub.com/aries-u802.html
Wed Jan 29, 2003 11:57 pm
12-20 isn't actually that high when you think about it.our cars run about 40-48 to the injectors in stock form, so what you're really doing is limiting the pressure to the solonoid to prevent it from sticking due to too much flow.
as for the fuel jet, that woud depend entirely on your setup.you say this is a wet port injection system, is it actually tapped into the runners before the cylinders, or is it just in front of the throttle body with a single nozzle?
This makes a huge difference in jet selection, as too large a fuel jet will simply bog down the motor and eliminate any gains that woulsd have been seen through the use of nitrous.
