Well in that case, yes its probably your heater core. When mine went, it leaked coolant out of the lower vents every time I turned it was horrible. In this case, just bypass the heater core (or replace it)n30r3b3l wrote:It smells a bit like coolant. The other day I was almost completely out of coolant and the car was over heating on me while I was traveling out of town and I had to stop and put water in it just to get back home. This was the day before the leaking so there wouldnt have been much coolant in there any way. Plus it hasn't really rained here in almost a month so I don't think it would be the drain for the T-tops. Also there was quite a bit of fluid leaking out on the ground. I'm not sure that much water could have been in that drain tube
