WET FLOOR
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
CHASMANN
Car: 2007 VERSA 2014 ALTIMA 2.5
iVE NOTICED A PROBLEM D/S WET FLOOR.aLSO CANT GET A/C LIGHT TO GO OFF OR REAR DEFROST TO GO ON.sorry to start with 3 problems but i think they might be related.just wondering if wiring runs under rug on front d/s 2007 Versa
PapaSmurf2k3
Site Admin
Welcome to NICO!
Wet floors are usually caused by clogged AC drains (or external leaks). Assuming you have all the factory glass and seals, its more likely to be the drain.
Check out the factory service manual to see where it might be.
www.nicoclub.com/fsm
I'm not sure if wiring runs along the driver's side floor or not, but I can imagine how frustrating it must be to have moisture in the cabin and no rear defroster... especially if that moisture is coming from the AC, which is stuck on.
Return to “Versa Technical Discussions”
