elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Tue Jan 24, 2006 11:38 am
you wont see much water in the winter, especially out in MD.....
That hose your referring to is for the temp sensor..... basically what it does is bring air in through the vent so that it is getting a constant reading..
the AC drain is DEFINITELY on the pass side. If you look just above the exhaust, you can see a L shaped tube pointing down..... Its hard to spot unless you know what your looking for..
To clean the sunroof drains, ive found this is the best way: Get a flexible straw, open the sunroof, and youll see the drains on both corners... Stick the straw in the hole and blow on it..... This will move the crap out... Now douche the drains with water..... And be sure that the water comes out just rearward of the respective side tire..... its like just foreward of the door, the drain actually comes out from behind the quarter panel...
