Structure240sx »
https://forums.nicoclub.com/structure240sx-u1949.html
Thu Dec 25, 2003 7:32 am
the cltuch used to slip often but not too much now. is it possible that it would slip slightly then grab under laod like that? maybe jsut a bad transmission? i have a new disc im waitin to put in for when i pick up a newer transmission. im not tryin to push 15psi on a 130,000mi transmission. my jwt ecu nismo injectors and z32 maf will be goin in next week along with a bung or the wideband o2 sensor my uncles shop uses so that should take care of timing and i can see if its the engine. im thinkin more of a transmission problem tho now. who knows
