werid noise
DeeZNuTTss
Car: 240sx 4/1991 hatchback s13
i get a werid sometimes when i start rolling backwords. it sounds like grinding somewhere in the back. the noise is loud and seams that the car is going to break. also in the morning or when my car hasn't been started for awhile, i push the cluth in and hold it and it also make a rubing grinding noise. does anyone else have this problem? thanks guys again
GroundZero
when was the last time you did your brakes?
DeeZNuTTss
not to long but i have replaced them and it still made the noise. but why only if going back wards?
Scott McLellan
Is it sound like it is coming from the back calipers.
Hijacker
Car: '92 240sx Convertible
'94 F-150
check to see if your rotors are warped in the back as well
NISTECH
check the plates behind your rotors they my be rubbing against the rotors. but it is odd the noise doesnt occur going forward if thats it. the other noise i would say is your pilot bushing spinning in the crankshaft
leper421
Car: Current: 2011 370z
Previous: 2003 350z, 1991 240sx
I had a clunking/clattering noise when I went in reverse sometimes. You could feel it too, not just hear it, like something was severely broken. I thought my differential was messed up, but it turned out to be one of my brake pads. It wasnt sitting in the caliper right, and wore away the top of the pad without touching the bottom. Check you brakes.
The noise when you disengage the clutch is most likely your throwout(release) bearing.
DeeZNuTTss
yeah i can feel it also. its loud as hell also. so im going to do you brakes and get the slotted rotors. are the rotors on ebay good? there blembo i think. about the clucth, is there any i can do to ffix that?
